The guys that own the powder coater that I use have a ski nautique ski boat. It's about 20' with a 351 inboard. It was hit by a train so he got it pretty cheap as you could imagine. He repaired to damage but the deck started cracking. He is replacing the deck with another he found. So they drilled all the rivits out and cleaned up the mating surfaces with sanders. The new deck is dry fit into place right now. They are getting ready to use adhesive all around and then drill and rivet it back together. He has some west marine 2 part epoxy adhesive that the local west marine recommended. It comes in tubes like caulk. I have never heard anyone on here using epoxy on a hull-deck joint before.
What adhesive do you recommend on this power boat? He never plans on taking it apart again, but he didn't plan on taking it apart this time.
