Power washing
16
2 26 Santa Cruz, California
Is it okay to power wash a fiberglass boat?
Problem: Redwood stain. Tannic (tannin) acid from redwood trees have stained, like polka dots all over the top of the boat.
Suggestions, thoughts, comments?
Thanks.
Aug 4, 2009
16
Good to know, however, I was under the impression that Oxalic acid was for wood only, not fiberglass?
Aug 11, 2006
1,446
Hunter H260 Traverse City
I powerwash my boat at the end of the season and it works great with no apparent damage. However, there is usually a green tint to the hull that is removed by "Slimy Grimy" - an amazing product that removes organic stains such as algae. I'd try this if normal household cleaners don't work.
Aug 3, 2005
181
Morgan 33 O/I Green Cove Springs FL
You can pressure wash
till the cows come home, but it wont remove tannin stains. You can use what Main Sail uses, Mary Kate On-Off Hull Cleaner, which works great for about $12.00 a pop or you can use Sno-Bowl toliet bowl cleaner for about $1.50 a pop. This also works great. your call.
Fair Winds
Dave
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
If you powerwash the deck of your boat, be really careful of anything that is caulked (i.e., ports, stanchions, hatches, etc.) as most powerwashers will remove it (don't ask me how I know....).
