BE CAREFUL!
Gil: Bill had good info for you but one thing he (sort of) left out is that whatever else you do, never, NEVER turn the battery selection switch to the "OFF" position with the engine running! You will likely fry all sorts of expensive equipment like your voltage regulator, alternator, etc. If you do a search through the archives you will find some interesting discussions on the subject! I suspect you are fairly new to sailing (welcome aboard, you are going to love it!) and highly recommend you go to your library and pick up any one of the numerous books on the subject of boat electrical systems. Even better, go to your local West Marine/Boat US store and brouse through their selections. Good luck!Tim Leighton (S/V "Magic" C-400)
