Power Requirements for AB Cold Machine
3,098
Beneteau 343 Slidell, LA
I am planning to convert the ice box on my '88 H33.5 to a refrigerator using an Adler Barbour Cold machine. I will probably reinsulate the interior of the box with vacuum panels. I currently have two GP 27 AGM batteries; one for starting and one for house power. The batteries are charged using a True Charge 20 mmicroprocessor controlled charger. I am only interested in using the refrigerator dockside while connected to shore power. Any recommendations on battery size and configuration would be appreciated. Thanks.
Jun 5, 2004
12
Hunter 30_88-94 Poulsbo, WA
Use 110 volt
If you are only going to use it dock side you must still be planning to also use it as an ice box while away from the dock. Right? Way not use 110 volt and forget all the expense of messing with the batteries? You could probably take apart a dorm room refrigerator which cost less them a hundred bucks. The hard part would be to do the install without breaking any lines and losing the coolant. While at the dock you could crank it up and get everything nice and cold before adding the ice. What do you think? steve
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Norcold
Norcold makes a great little icebox conversion unit. The mechine runs on 110V at the dock and 12v when not pluged in. It automaticly sensses and switches over. It's inexpensive and easy to install. http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=6290
Jun 1, 2004
13
Hunter Vision 32 Lake Lanier
Isotherm Makes an Interesting Unit . . .
that uses DC to freeze a holding plate, and an electronic ASU (Automatic Start Up) energy managemenbt system to reduce power drain on your batteries while away from the dock. For weekend cruisers, it looks like it could cut the power drain on your batteries by half over a standard evaporator unit like the Adler Barbour. It seems to be cost competative too. You can find them listed in the 2004 Defender catalog.
Jun 6, 2004
10
Hunter 35.5 New Hamburg, NY
I have the same set up
that you are suggesting. It works well at the dock and when you are under sail or at a mooring just remember to switch from both to number 2 leaving number 1 for starting.
Jun 21, 2004
3,098
Norcold Refrigerator
Pat, I currently have a Norcold AC/DC icebox conversion. Probably because of the poor insulation in the box, the size of the box, and ofcourse the hot weather on the Gulf Coast, the unit ran continuously and never really cooled very much. It finally died last year.
Jun 3, 2004
347
Wow!!
Whaen I installed the Norcold in my 30 I did add alittle insulation. It ran alot but I don't remember it running continusly. Must be the difference of a few hundred miles.
