I presently have a xantrex 1750 watt inverter(1500 watt continuous) on my boat. It has two outlets. The electrician wired a standard house plug(which plugs into one outlet of the inverter) and wired the other end into the power panel for use when switched from Shore Power to Inverter Power. I have three 850(if memory serves) Deep Cycle batteries. When using the 750 Watt microwave, the microwave makes a real labouring sound like its struggling and most times does put the inverter into alarm.
There are two reset breakers on the inverter. My question is, within the inverter circuit, are there two separate 750 watt outputs or a 1500 watt output shared by the two plugs? I'm trying to figure out why a 1500 watt inverter won't run a 750 watt microwave. If two separate circuits, is there a way to wire the two 750 outputs to provide the panel with the full 1500 watts?
