still not convinced but I agree regardless
Running a battery bank in parallel is certainly a controversial topic on sailboat e-mail lists. I do it myself (4 - 6V Trojans in parallel/series) so no one gets an argument from me. I do, however think it's somewhat of a crap shoot, both from a technical, as well as a strategic point of view for the following reason(s). As Stu implies, let the user make an informed judgement. Two brand new batteries of identical type and capacity can be operated in parallel, and the nominal capacity of the 'bank' will indeed be twice the capacity of each battery. For some period of time, they will continue to operate in this fashion; during recharge, each battery will draw the same current, and their electrochemical conditions will be identical. However, as the batteries age due to manufacturing tolerances and so forth, their electrochemical condition may differ.At some point, the weaker battery will begin to draw measurable current from the stronger one, and the total capacity will diminish. There is a possibility that one of the batteries will develop a shorted cell, and the result will be that the other battery will be dumping a huge amount of current into the damaged one Granted, it rarely happens and probably won’t in the first few years of battery life, but why take a chance? Is there anyone here who has never had a battery in their boat, car, tractor, etc fail? I think so! There's another problem with running batteries in parallel. As in the original poster's message, let's assume you've got a pair of identical batteries, which you are using sequentially. When one of them becomes depleted, you start your engine, and the alternator attempts to recharge the battery. Chances are good that the alternator will be working fairly hard, in the first hour or two, to supply the amount of current that the battery will accept. Eventually, the terminal voltage rises, the current reduces, and you reach a fully charged condition. Now let's assume that you've got the same two batteries, in parallel and you deplete them to the same level as in the previous example. The problem now is that you need twice the current to recharge the 'bank' in the same time period, but alternators are not linear devices, and you won't get twice the current, because heating will lower the maximum output, and you're asking the alternator to do twice the work as in the previous example.
