pourable foam
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
Anyone with any first-hand experience using pourable foam-ie;U.S. Composites or any other brand? They come in varying densities from soft to hard to fill voids for varied applications. Thanks, Ron
Mar 13, 2009
158
irwin 37 (73-74) grand harbor marina
that stuff is amazeing! got some from a local taxidermist, $50.00 for part a & b. usd it to fill the voids in a home built tri-hull. used a hacksaw blade to trim it flush before putting on the lid. haven't tried the hard set foam yet. it will push and cause buldges if confined.
txjim
Sep 4, 2007
154
Hunter 170 Grapevine Lake, TX
I bought the 8lb foam from http://www.uscomposites.com/foam.html; amazing stuff. This was to provide structural support for a deck and it's working very well. It was easier to mix/apply than I expected. You do have to make sure you have a contained area to pour the liquid as it's pretty thin when mixed and will run off quickly. The web site provides load ratings and I can attest that it has good adhesive properties as well. In my application, I had to trim the final foam set using a saw and a Dremel Multi-max with scraper tool.
It's worth a few ounces of the product to do a trial run in a test environment so you can get a general idea of the rise time, expansion characteristics, etc...
