Ok, sorry to post something worrysome, but I felt it was the most responsible thing to do.
I just had my rig pulled on my 49.
I haven’t had it off the deck since purchase, and couldn’t put it off any longer in good conscience.
Please understand, that is fortunate fresh water sailors get a little complacent on rigging, as it always looks like new.
So, decided to do a major overhaul on the rig, including all new halyards, lighting, wiring, etc.
At the same time, I wanted to have the forestay furler stripped down, just to make sure it was all 100%. The gentleman who did this is a professional rigger, and really knows his stuff.
One of the things I’ve noticed over the last 2 seasons was mast rocking, and it appeared that the rigging needed to be tightened. I thought that a full rig service would figure all this out.
Well… an almost-disaster in the making, and I suggest people thing about putting this on an inspection list.
The Selden forestay furler on my boat was installed by Hunter, which I assume is the situation with most boats out there; irrespective of brand.
Installation of the furler to the forestay is identical to a Norseman fitting: where strands are unwound, formed over a cone, bent inwards, and then a compression nut it tightened down.
So, the first photos show the unwound strands over the ferrule , but that’s all they did before winding down the compression nut.
They missed the MOST crucial step, which is imparting a slight bend in the strands, which locks the wire in place.
Without doing this, the strands can, and will, start to slip backwards. In my case, I did indeed notice forestay slack, and the mast pumping on made this progressively worse.
At some point, this could have been disastrous, with the forestay pulling clean out.
I’m suggesting that people find a way to ensure their forestay attachment complies with Selden’s procedure of bending the wires past the ferrule.
I hope this is helpful
