Another example of the few making it difficult for the many, http://www.keysnet.com/2013/08/24/489480/key-largo-liveaboards-beg-to-keep.html . Chuck
I didn't say it was dumb,
Maybe I don't know what WADR means.
If it were up to me, I would hope that there was open access to anchorages up and down the coast. And that those in the anchorages would behave in way that would make them welcome. But the world is not as I wish. Or anything close.
they got no kahonies any more..........just stupid gall....Why is it always so much easier to paint a whole group of people with a broad brush than it is to actually arrest/cite and fine the ones that are actually causing the problem.
This is essentially the solution that was reached in Boot Key harbor or "Marathon, Fl." Before the widespread use of municipal mooring fields, the water was THICK with human excrement so thick that only a complete fool would swim in the water. The municipality took over the marina, mandated regular weekly pumpouts via two municipal owned pump out boats .... the Marathon now operates the marina at a profit, the water has cleaned up considerably, most of the riff-raff simply moved on.One way to fix this sort of situation is to require anchored liveaboards to maintain pump out logs to be stamped by the pump out operator.
The residents and tourists DON'T have to put up with poor behavior.
ExactlyWhy is it always so much easier to paint a whole group of people with a broad brush than it is to actually arrest/cite and fine the ones that are actually causing the problem.
Well said Rich.This is essentially the solution that was reached in Boot Key harbor or "Marathon, Fl." Before the widespread use of municipal mooring fields, the water was THICK with human excrement so thick that only a complete fool would swim in the water. The municipality took over the marina, mandated regular weekly pumpouts via two municipal owned pump out boats .... the Marathon now operates the marina at a profit, the water has cleaned up considerably, most of the riff-raff simply moved on.
Marathon is now a staging area for boats sailing on to the Bahamas and South or to Central America, .... and for Canadians and other foreign nationals - Cuba.
The moorings at Marathon are at reasonable cost, the marina rules are tightly enforced (still a bit too authoritarian for those with gilded boats) ... but it works, ...... and Marathon's commerce is increasing due to the fact that ... its a good and well run place to be either for a winter stay or to visit as a staging area / jump off area for further south.
Once you get the typical 'live-aboard' with two feet of sea life encrustation attached to the hulls, four months worth of 'trash' piled on the decks, rising crime and rampant misbehavior, using the harbor as an open cesspool .... if this happened in YOUR neighborhood, you'd demand action too.
Moorings and their cost is a small price to pay for a safe, clean and well run harbor. Marathon has already proved that principal ... and makes a handsome profit to boot in doing so.
