Potential engine problem
187
Hunter 33.5 Missouri
Motored back to the marina today, about 25 minutes at 2500 rpm on our M18 Universal. Making steady 6 knots, engine temp never exceeded 165. Everything normal. Reduced speed passing entrance to harbor, idled down and motored in for another 5 minutes to the pump out dock. I leave the motor running while pumping out, about 7 minutes and then head to the slip. Having finished the pump out and preparing to leave the dock I see a fair number of what appear to be black oil droplets on top of the water at the stern. Instinct says check the exhaust outflow. Water flow was normal and no trace of any oil there. I look around to see if there is anyone nearby who might have caused this. Don't see anyone. Now wondering if it was from us. Not small droplets, about the size of nickels and quarters and more than I cared to count. Checked the engine oil back at the slip and it was normal. I'm hoping it was from another boat but still concerned because I didn't noticed it approaching the dock and it was quite close to the stern when I finished. Any thoughts or speculation. I don't want to overreact but when there's a small flotilla of oil behind your boat alarms go off.
Steve
Ross
Jun 15, 2004
14,693
Wipe the entire engine looking for oil. Is you bilge dry? did the bilge pump run at pumpout? Engine oil in the exhaust would be blue smoke.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Was it rainbow colored like oil or dark black, if you were idling at the pump out you might have just built up some carbon that blew out one you throttled up.
Feb 27, 2005
187
The bilge pump didn't run nor was there any oil present when I checked the bilge. I also checked beneath the engine and the compartment. So, I'm thinking it was coincidence. I let the engine idle for about 5 minutes at the slip and no visible smoke.
Was there any cr*p when you idled at the slip? If not, coincidence. Good luck.
PS - BTW, I'd shut the engine off for those 7 minutes. Why waste fuel and exhaust air, etc.?
capta
Jun 4, 2009
5,102
Possibly you just stirred up some fuel or oil lingering around the dock when you came in?
May 24, 2004
7,228
CC 30 South Florida
Remember Diesel Fuel in water acts just like oil. Years ago we busted a fresh water hose and having the water pressure on I guess we emptied a large portion of of our fresh water tank into the bilge. The bilge pump did its job and expelled it out and then we found out where all that diesel fuel went when we blead air out of the lines and replaced filters on the run.
