How to recommission the fresh water system
Although most people think only in terms of the tank, the plumbing is actually the source of most foul water, because the molds, mildew, fungi and bacteria which cause it thrive in damp dark places, not under water. There are all kinds of products sold that claim to keep onboard water fresh, but all that’s really necessary is an annual or in especially warm climates, semi-annual recommissioning of the entire system—tank and plumbing. The following recommendations conform to section 10.8 in the A-1 192 code covering electrical, plumbing, and heating of recreational vehicles. The solution is approved and recommended by competent health officials. It may be used in a new system a used one that has not been used for a period of time, or one that may have been contaminated. Before beginning, turn off hot water heater at the breaker; do not turn it on again until the entire recommissioning is complete. Icemakers should be left running to allow cleaning out of the water feed line; however the first two buckets of ice—the bucket generated during recommissioning and the first bucketful afterward--should be discarded. 1. Fill the tank with a solution of 1 quart Clorox or Purex household bleach/50 gallons of water. 2. Open every faucet on the boat and let water run till what's coming out smells strongly of bleach. Then close all faucets, but do not turn off the pump; it must remain on to keep the system pressurized and the solution in the lines. 3. Allow to stand for at least three hours, but *no longer than 24 hours.*4 Drain through every faucet on the boat (and if you haven't done this in a while, it's a good idea to remove any diffusion screens from the faucets, because what's likely to come out will clog them). Fill the tank again with fresh water only, drain again through every faucet on the boat. 5. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart distilled white vinegar to five gallons water and allow this solution to agitate in tank for several days by vehicle motion. If the bleach has been thoroughly flushed out of the system, it is not necessary to fill the tank more than 1/3 full.6. Drain tank again through every faucet, and flush the lines again by filling the tank 1/4-1/2 full with potable water...drain again and fill tank for use.This will remove all antifreeze taste/odor. An annual or semi-annual recommissioning according to the above directions is all that should be necessary to keep your water tasting and smelling as good as anything that comes out of any faucet on land. If you need to improve on that, install a water filter. Just remember that a filter is not a substitute for recommissioning the system, and that filters require regular inspection and cleaning or replacement.
