apologies for the newbie type question/details..
due to little wind and over 100nm to cover had to motor for many hours. on the second day noticed the carpet over the rear bilge in the galley was soaked. opened the rear engine compartment door to see water being sprayed all over from the turning shaft. immediately put in neutral and turned the bilge pump onto manual which cleared out the water. after pausing for awhile with no harbor or suitable anchorage nearby went ahead and started motoring on at lower rpms at first. kept repeatedly checking and even after higher rpms was completely dry for the rest of the trip.
could this be water from the stuffing box? either it's too much or could it be that over the course of many hours just filled up the bilge? (not certain that the auto float switch is working properly - which of course need to look at as well).
if there's any question of all want to take to a yard to have inspected.
