Josh Peskin
I've been searching through the archives to put together a coherent game plan for sealing my 1978 37-C. The ports are a must before the winter, but I'm thinking that I should approach the leaky ports from the top down. That is, first do the test for the Dorade boxes (plugging the air vent and filling them with water, and then seeing if any water leaks in) to see if water is leaking into the deck. A side note: Are there other spots notorious for leaking water into the deck? However, my deck, when tapped, does not sound too bad. So the issue is whether or not, before dealing with the ports, I should try to figure out where leaks come into the deck, address those, and then turn to replacing the ports. Even though the winter seems a ways off, I suspect there would be a time crunch if I try to seal and fill any bad spots in the deck, and only afterwards take care of the ports, but on the other hand, I don't want to take out the ports, scrape away the bad wood, put some sort of epoxy in there, and then seal new ports to the epoxy, only to have sent the water somewhere else, which will cause me other problems. Can the water travel that far, or have people found that these are separate problems? If leaks into the deck do not affect the ports, I would probably prefer to tackle those first. Also, could one of the veterans point me to what they consider the best step-by-step account of installing new portholes in the archives or elsewhere(foam or epoxy, smartest gameplan, best type of silicon, etc.) Anyone who wants to talk more about this, please feel free to email me at jpeskin@stanford.edu Thanks for the responses to my last post.
