Porthole rot fix H37c
194
Hunter cutter 37 1981 St-lambert
Once again, Mathurin II has an apointment with the boat doctor... This time the rot behind the portholes is being taken care of. Here a few pictures and a little video of the process.
http://youtu.be/OJNEFmB6MTg
Once again some surprises, a previous owner had used a dish rag as core material :doh:
5,802
Wow, when you decide to fix something there is no half-way! Ten years ago I installed bronze Newfound Metal portlights. A few of my perimeter frames were wet and a bit rotten. I just dug out the rot and glassed in some perimeter plywood. Actually had to do that with all the big ports because the holes were 7x15 and NFM only had 7x14 at the time. Would give a lot to have the time and facilities to do your kind of work. Looking forward to more pics as you progress.
Phillipe, you do not do things by half measures! When I replaced my Gray ports with Beckson about 8 or 9 years ago, I used a router to cut back the core by about 1/2". Then I filled the gap with epoxy putty before installing the new ones. Someday I hope to put in NFM metal ports like Ed S did (when I win the lottery!). I have been lucky not to have any major soft spots in the plywood core yet. What kind of paint do you use when your deck and cabin repairs are complete? How does the deck paint look a couple of years after your extensive rebuild?
Merci,
Jim
Jul 7, 2009
252
Beneteau First 405 Myrtle Beach, S.C.
Boy, oh boy. Not for the faint heart. Please show us the closed seems and the final paint job also. I know I also have to do that some day. My side decks are "crunchy" when I walk on them. I am simply delaying the inevitable.
Jose
May 31, 2007
784
Hunter 37 cutter Blind River
Only my starboard side coachroof was rotted and wet. Port side was fine. I attacked the issue from the inside and all I need to do now is add a bit of trim to the cut lines on the interior liner. The great advantage of excising from the outside is that things like bulkheads don't get in the way.
Sep 10, 2009
194
I can't recall exactly the paint we've applied, I'll look at that next time I'm home. What I can tell you is that we applied an epoxy primer to seal the surface then we applied paint (was it uretane? I can't recall). The paint still look great, I only have 1-2 touch up to do. We've used too much fairing in some areas, resulting in some stress cracks (only in surface, the laminate in intact).
Sandpiper, doing the deck from outside was quite easy (easy is probalby not the best word to describe the job). I can't imagine doing it from the inside, the mess it must create ! You are a courageous man. Furthermore, the deck anti-skid on deck is very easy to replicate with a stucco roller, so it's very easy to hide the job.
For those who aven't seen the deck recore on MATHURIN2 here some pictures of the job: http://mathurin2.blogspot.com/2010/09/les-renos.html
The NFM stainless steel ports that are going to be reinstalled after the job is done:
http://forums.hunter.sailboatowners.com/showthread.php?t=127323
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
Coach Roof Rot
Merry Christmas and Happy New Year Phillipe and Robert! Hope all is well .. aside from the rot.
I may have to call you for advice! I've found some soft spots in my coach roof. I hope it isn't as extensive as yours ;-)
Ron
Sep 10, 2009
194
Hey Ron, Merry Christmas to you too !
Everything is going good up here, my dad is once again spending time getting Mathurin II in the best possible shape, which keeps him active, and on my side, I'm in over my head with school (why on hearth did I say yes to that Master degree, I would rater be down south enjoying the sun !!!).
Feel free to call or email me/dad is you have questions, the faster you fix it the easier it's gonna be.
