Portal Window Gaskets
P
Pitman
I just got in my second shipment of gaskets for my portals on my 1984 Hunter31. Again the wrong part. I have 7” by 14” Bomar portals. It looks like the same Portals were used on the Hunter 31 & Hunter 34. What I need is the part number for the rubber O ring gasket that fits into the plastic window. I went to the archives and got a part number, but this does not seem to be the right one. HELP!!!
Dec 2, 1999
15,184
I think that these are the sizes.
Pitman: I think that the larger ports are 5 1/2" x 12 1/2" (6 of these) and 4 1/2" x 14 1/2" (aft quarter berth).
P
Pitman
Need the rubber gasket size
Steve do you know the rubber gasket size. My portals are starting to leak due to failing gaskets. Thanks
Dec 2, 1999
15,184
Contact Thrifty Mariner
Pitman: Contact Thrifty Mariner (www.thriftymariner.com) Tell Jeff the size of the ports and he should be able to give your the gasket sizes.
