Thanks Peggie, you picked up on what I'm trying to do. I meant to say deck fitting instead of through hull. I have found an assortment that will work that include the cap. No easy task finding the right size hole saw but am hopeful. I plan to use the 1 1/2' which seem to be adequate for all pump stations, and one with a barbed fitting for hose on the underside. The plan, is to install the fitting and simply run a short hose to the bottom of the holding tank. Not perfect, but it should get most of the contents, particularly if using a bag of stuff that came with the toilet. It helps with odor, but to my pleasant surprise, turns all the stuff into a liquid. Where I'm at a dead end is the hose. It needs to be flexible enough to curve over to the tank, and still be 1 1/2" ID. I know, it would be messy to remove the hose and clean, but I don't see an easier option. I don't want a fixed plumbing affair, that opens you up to USCG inspection. Plus, if I need to, or find one, I can still pull the tank and dump it. One would think hose that size would be common, but no luck so far. There is some corrugated stuff, but I prefer a slick inner tube that would not trap crap on the sides. I welcome any ideas or further advice you might offer. Thanks, Dave
