Portable (standing) AC Units - Which brand?
zeehag
Mar 26, 2009
3,198
aftermuch research and hemming and hawing 3 1/2 yrs ago in hotville, mazatlan, i bought a window unit t hat drains out onto deck, not inside cabin and does not discharge heat back into boat.
all a/c units make heat. free standing ones as well as window units. the heat has to go somewhere so i chose out the back into the waist of boat.
but then i has formosa windows for one, and it is easy to remove and reinstall.
kito
Sep 13, 2012
2,011
No must have for me, but must have if I want my wife to join me during another hot weekend. Thinking many here can understand that.
Ditto that!. Especially if you was planning on some "V-berth boogie" later on ;)
zeehag
Mar 26, 2009
3,198
i bought mine for my cat, who was melting in summer heat....
May 23, 2004
3,319
One of my wife's biggest complaints has always been the heat. She gets migraines from it. I also have a hard time sleeping when the cabin temps are 80 degrees or hotter.
We have been blessed this summer in the Chesapeake Bay region with very mild temps. The cruising here during July and August can be awful and I have even experienced really bad heat in the end of May. When temps get to a certain point I hate going into an anchorage and that usually means I stop cruising for the heat wave.
A lot can be said for cooling the boat down. Some may get use to it but others can be done in by it.
I will eventually go the portable AC route someday.
zeehag
Mar 26, 2009
3,198
sorry i forgotto mention the brand nname of the unit i picked up for 140 usd in mazatlan. they sell for 75 usd in usa..is LG, a 5000 btu unit. works well.
Dec 11, 2008
1,338
catalina C27 stillwater
Go see my AC install in my refurb thread in the Catalina Mid-size boats forum.
I am running an 8K BTU window unit in a bulkhead between the cabin and a cockpit lazarette. It drains into a shower sump. Air exchange in the laz is handled by a 95CFM squirrel cafe fan.
It cools my 27 down quick. Even in 120* temps inside my un-insulated shop.
The install cosmetically looks built-in yet without the cost of a marine unit. One bonus: it works on the hard.... :)
Dec 11, 2008
1,338
The AC install starts on page 15. Don't get too confused as you read through. I actually installed two units before I was happy. The first unit pointed to a few mechanical issues that needed to be addressed. It was also only 5K BTU.
The second unit proved ideal. It is installed so that condensation drains properly. It is a surprisingly short unit height - wise... It seems height is usually the key dimension to figure out what you can fit. I think the 8K unit I bought is probably the least-tall unit on the market:
http://forums.catalina.sailboatowners.com/showthread.php?t=123450&page=15
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
Speaking from the perspective of an HVAC pro/energy efficiency engineer, I'd say the single-hose portable a/c units are ridiculously bad.
If you must get a portable a/c unit, get a dual hose unit. The brand doesn't matter, most of them are made by the same Chinese outfit and have the same internal machinery with cosmetic covering and a feature or two as specified by the company that owns the brand name.
If you go ahead with a single-hose, well you should get the smallest one they make and minimize your mistake. Put it close enough so that you can feel the cold draft on your skin. Buy earplugs, they are all noisy, even the dual hose units.
Overall, you are better to reduce the heat gain to your boat (shading and ventilation), add fans for air movement (fans actually add a little heat, so turn them off when you are out of their reach), and spend more time on deck. If you still need cooling, the best way to go is water-cooled a/c or heat pump. If you decide on air-cooled, at least use outdoor air as your heat sink, not indoor air like the single hose ripoff units use. Small window units that you can get for cheap are outdoor-air-cooled, less noisy inside, and drain condensate outdoors.
zeehag
Mar 26, 2009
3,198
i found my LG brand 5000ntu a/c window unit much more efficient than any built in marine unit i have experienced.
they are also very cost effective.
i live in tropical areas on my boat, and i have found tropical summers require a nice efficient unit. my LG is perfect. i use a fan to move air to other areas of boat and i am most happy. so is bubba daboatkat.
humidity is lowered, and boat is pleasant. i keep it on low settings fro removal of excess water. isnt much needed for temperature as we keep 85-90F year round.
as water temps are also a factor in comfort, an das our water is 85 in winter and 100 in summer, is a necessary item, unless you just love heat and humidity.
keeping sun off decks is most important- you will find with decks covered and coachhouse covered, you will drop interior temps up to 10 degrees. appearance is not a problem, as all boats here cover for summer. (appearance does not make a difference with me--i donot care to look like a snotty richie rich with too much money with shiney boat magnet fro bandidos.)
May 24, 2004
7,228
CC 30 South Florida
One last final comment, it seems that the larger the boat the better a portable seems to work as they have a larger volume of air to play with. The larger boat can retain a larger volume of already cooled air for much longer. This reduces the effects of the hot humid air creeping back in from the outside. There is one caveat and that is that there will be a larger area of deck and topsides radiating heat to the inside so the maxim that the bigger the boat the more BTU are needed still stands but the unit will work more efficiently in a larger area.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
why not get a unit from an old surplus airplane? Should be light, corrosion resistant and very efficient
zeehag
Mar 26, 2009
3,198
one answer for the radiant heat problem--TARP the boat so decks are not in sun.. lol is soo easy, and it works sooo well...
Oct 15, 2009
220
catalina 320 Perry Lake
In my opinion, and I've tried the free standing unit, it is much better and takes up much less room to get a small window unit, mount a handle on top for ease of carrying, and make temporary hatchboards so you can put it in the companionway. It drains into the cockpit.
Feb 22, 2004
222
Hunter H340 Michigan City
I have the Cruisair® Air hatch mount to use on the days it is hot and humid at the dock. works well. Both my wife and I think it works well I set it on lo cool and thermostat about mid point once it initially cools down.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
We have an Irwin 34 and this is the unit we bought, http://www.bestbuy.com/site/danby-8000-btu-portable-air-conditioner-white/1980337.p?id=1218330802464&skuId=1980337&st=categoryid$abcat0907004&cp=1&lp=3
Its a danby 8000btu. It may be a tad small in BTU but it fits perfect where we wanted to put it. If really hot outside I set it on the counter top next to the sink and stove. It fits there just right. This also has the effect of cooling the air from the very top of the interior down and has worked fine for us. We do close off the V-berth until the cabin gets cool then we open it up again. We run the regular fans to help circulate the cool air. We have our boat in Middle River , Md. This unit is small enough for me to lift it up there when needed and then when going out sailing I set it on the floor in the galley area. It's small enough to be able to work around. If we just need a little cooling for sleeping then I leave it on the floor. I made a plywood vent board to fit our portlight and I just lock that in and run the hose to it. After running for a day I only have about half cup of water to drain and I just pull the unit to the side of the counter and drain into a cup and dump it that way.
For us it was a matter of size,weight and needing to fit where wanted it.
Brian
Aug 15, 2014
114
Catalina 36 Deale, MD
It boils down to this for me as well. Will know more on Sunday if the LG 10,000 BTU has the right footprint or not. Keeping it in the box until then.
Can anyone point to a template to make a removable plug for the Lewmar "old standard" port? From Catalina Direct, the dimension are:
•Height: 133mm (about 5-1/4")
•Width: 309mm (about 12-5/32")
But I don't have the radius or know if the plug should be larger or smaller of if some notches are required. Hope to fab something up before heading to the slip.
kito
Sep 13, 2012
2,011
I made my plug out of foam. The kind the interlocking floor mats are made of. I am not using the oblong adapter mine came with. I just cut a piece of foam to fit snug in the port with the window open. I then just cut a 4" hole in the foam for the hose to fit in. Friction keeps it in place and seals well. Actually I have 2 hoses in mine..exhaust and inlet.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Consumer reports just did a study (for home use) of portable units and if I recall they didn't like any of them and apparently none of them could come close to meeting published specs. I suggest going to the local library and have a look for yourself.
Ken
Aug 15, 2014
114
Well the high was 91F on Sat and the boat was sweltering inside at the slip. The LG 10,000 BTU unit did a good job at cooling down and drying out the boat. It was impressive how hot that exhaust tube gets and I can understand how an insulated tube is the only way to go so the supplied exhaust tube was tossed for a well insulated one.
As of now, the AC unit is in the head but I will work on a better location later. When departing for a sail Sun afternoon, it was easy enough to handle and move the AC unit to the finger pier. The condensation pan had perhaps a pint of H2O in it after running for nearly 24 hours so the auto evaporation system is working.
Mar 19, 2013
75
Beneteau First 38 Chicago
Great idea Kito. I will do that. The duct tape is a pain and not very "pretty". I did buy the foil covered duct insulation for the exhaust and it really helped.
