porta pottie suction hose
May 21, 2007
11
Oday 26 -
I have been reading lots of good info here for some time now. i now have a ?
Recently I purchased a new msd style porta pottie,the existing hoses are the same size and will fit. However the PO removed a piece of teak above and behind the porta pottie and I would like to reinstall this piece. My problem is that this will effect the 1.5 inch suction hose. Their will be a slight kink in the hose if I replace the teak,will this effect the suction when i have the toilet pumped.Or is their a more flexible hose to use for this purpose.
Jan 4, 2006
7,770
This is why you want to use wire wound sanitation hose:
a) to withstand the negative pressure and not collapse when being pumped out.
b) to be able to go around tight bends and not collapse.
A picture would help to see exactly what the detour looks like.
