Port Window Replacement / Water Leaks
Jim Nixon
I am looking for the replacement window for head that opens. Does any body know where to find it? I am having problems with a water leak that comes out the port side of the V-Berth at the light. I have re-beaded the stanchions and windows, I have water standing on the inside of the head window, it seams that the angle of the window keeps it from draining properly, I wonder if this is where the water is coming from. Any advice will be much appreciated.
Steve Linsk
Replacement Windows
I called Catalina's parts department to replace the crazed windows on my 1986 Cat30. They told me they no longer carry the parts and I should try "Go Windows" at 909-735-7705. Go will need to know if your current windows are stock or aftermarket and if so, what the brand is. Good luck!
