Pop Top Hold Up
StuartDon't be afraid to re-engineer your boat, you may come up with something better.If your boat was set up like mine, a 26D, there will be a sliding bracket at the base of your mast in the bolt rope slot. It has shallow 1/4-20 threads in it. After lifting th pop top, you are suppose to align the threaded hole and bolt on the sliding bracket with a hole on the forward edge of the pop top, and screw in the bolt through the hole in the pop top. Of course, the pop top was never made to sit on and the whole assembly just keeps the pop top from falling down.Do you have the bracket? Do you still want a pic? John S
