You're joking, right?
If not, the answer is yes, you can. You need a covered pan, and if you've never popped popcorn on a stove before don't use your favorite pan. Add a bit of oil to the pan (I like to use a decent olive oil) pour in a little popcorn cover and apply heat (you can pre-heat the oil and I think that gives better results but you don't need to). After a bit the popcorn will begin to pop. If you've put a bunch of corn into the pan the pan will quickly begin to overflow. Remove the pan from the heat, when the popping has slowed very carefully open a small gap between the pan the it's lid and shake out the excess popped corn into your bowl. Put the pan back onto the burner until all the popcorn is popped. With a bit of practice you should be able to pop all the corn in less time than you could in a microwave and, because you'll use good oil, with better tasting results... Experiment with the amount of oil and popcorn and heat and try shaking the pan while the popcorn is cooking. You've got it right when all the corn pops and none of it burns.
But, you knew that.... No?
--Tom.
