Pop Top Hatch supports
40
After I wrapped my removable Pop Top hatch supports with floating material so that I wouldn't lose them, I lost one (at least it's floating somewhere). Does anyone know where I can get a replacement for my Mac 22 or perhaps have a good idea on fabricating one. Thanks!
Oct 3, 2007
70
MacGregor 26D Salem Harbor
I made one...
I went to Lowes or Home Depot and bought an extendable closet rod. Flattened the ends with a vice to match the one I still had, set it for length and drilled a couple of holes for rivets to hold it at the right length.
Have been using for 1 year, so far.:)
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
I would be careful using the curtain rod, the stuff I have seen is way thinner than the oem supports, and Mac put stainless ends on for a reason. I had one of mine break on me, looked fine untill it snapped, internal corrosion. Nice bump on the head, and the other one followed the broken one overboard. Not a good design overall. Not to pimp my own mod, but the gas struts are much safer and easier to use. Frank(Caguy) put the details of the mod in the 25 section.
Oct 24, 2008
424
Macgregor 25 (1984) Wildomar, So. Cal.
Timo, how did you come up with the numbers for the struts? Or was it what was readily available?
Timo42
Mar 26, 2007
1,042
Magic...figured out where the strut would fit without interference with arms, measured length, went with slightly longer strut, tried 45lb struts, based on estimated weight of top, not quite enough support, went to next larger readily available size, 90lb, verified operation. Bob's your uncle.
caguy
Sep 22, 2006
4,004
I picked up a pair at the wrecking yard from a Volvo hatch back (Vanagon hatch struts also work.) Got the struts and mounting hardware for $13. When setting mine up I restricted the rise slightly for a little more boom clearance when the top is up. I like to sail with the top up. I'm only 5'8'' so it works for me and I still have plenty of head room.
Oct 24, 2008
424
Good deal! Thanks! I have seen others out there that are 60-80lb capacity, but it sounds like 90 would be the better way to go.
I'll have to look for some of those Volvo struts as well - great idea, Frank!
Dan D
Apr 6, 2007
55
Hunter 28 Leech Lake - Minnesota
On my 26S, I can vouch for 90lb gas struts too. Since installing them 2 seasons ago, I have not had to go thru the agony of trying to attach that wing nut and mast bolt to keep the pop top in position. Just lift it up and done!
Jul 23, 2009
5
Venture V222 Port Arthur
I have one at the bottom of Lake Sabine that you can have.
Anyway, what I use is a 1" ratchet strap looped around the upper side of the front hinge support and adjusted in length to hook on the mast bolt. This allows the top to lay back over the cockpit like a bimini hard top. It keeps the sun off and allows the boom just enough clearance.
I like the other recommendations too.
Good luck!
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
The PO tied a string between the two pop top supports. This makes it a lot harder to lose one even if dropped. The added advantage is that it makes a great place to hang stuff (eg. towels, bathing suit etc.) to dry.
Montgomery 17, Venture of Newport, Mirror sailing dinghy, El Toro sailing dinghy Mound, MN -- Lake Minnetonka
I like it!
What a great elegantly simple idea!
Oct 18, 2007
707
Macgregor 26S Lucama, NC
Dan D- Do you have a pic of the installation on a 26S? I'm interested, but have not figured out where to put them on a 26S. Any help would be appreciated. -Paul
Oct 18, 2007
707
Dan D- a pic IS worth a thousand words. I had been trying to figure how to mount them between the cabin roof and the potop itself, and just couldn't see it. Thanks. -Paul
May 21, 2009
13
Venture by Macgregor Venture 25 Alexandria, VA
Use struts
SO along with many others, I too added the struts to my pop top. I bought mine at autozone for 18 bucks a piece and followed the directions listed in one of the forums on here. Was slightly frustrated doing this solo, but in the end it worked well and only took a couple hours.
RNC725
Sep 25, 2008
51
Hunter 326 Lake Thurmond, GA
I'm thinking it should work on our boat, a 91 26c. Any tips? Suggestions? Photos? I'm not that handy but have a good buddy that is and he loves to sail -- it's a great tradeoff! my email is RNC725@comcast.net
thanks
Bobby
Sep 25, 2008
40
Thanks to all for yoiur comments and suggestions and especially providing pictures. I really like the gas strut idea, now just need to find the 90 lb ones. Good sailing!
