W
Warren
As we near a dreadful sailing season here in the northeast I have a nagging problem with my boat under power. First season with a 1989 Catalina 30 Tall Rig. I have the Universal M25XP, two blade prop I think it is a 13RH 12P. I get around 3200RPM out of the engine, however I cannot get above 5 kts, and in some sea conditions under 3kts. Since the first week of owning the boat my speed indicator has not operated so I am basing these numbers on both a mounted and handheld GPS. I have had a leaking packing gland that I have been able to get under control, until I re-pack it over the winter. Before I have the boat pulled in early November should I have a mechanic take a look, or will they be able to tell what the problem is after the boat is hauled. From reading the postings on this and othe sites, this boat should be able to obtain much higher speeds under power. The other variable is the bottom condition. I was not given a say in what went on to the bottom (long story) but they used the worst paint possible. I hope I do not offend anybody but Petitit Unepoxy, I watched the yard slap it on every bottom in the place. I know the condition of the bottom can greatly effect the speed, but under sail in moderate winds (10-15 kts) I can get 5kts easily. Any advise would be appreciated.
