Hello all...I recently had a freeze up of my freezer holding plate and after defrosting the freezer and the compressor unit I now have a pool of water under my engine. I thought that there must be a drain hole down there somewhere that is clogged? I felt around as far as I could reach and could not find one? Does anyone know if there is a drain hole somewhere under the engine that would allow the water to flow into the bilge? If there is not one why?:cry: I was hoping not to have to get out the shop vac..
