I made an attempt to reseat a fixed port on the roof of cabin of my Ben352 last summer. I used silicone adhesive/sealant, which was recommended by others. The repair didn't work and it started leaking again in a month. The port is a challenge as it has no frame or screws to hold it in place. It just sits in a depression on the fiberglass roof with about a 3/4 inch overlap. The port is made of plexiglass.
I was thinking of using polyurethane glue for the next attempt - specifically Gorilla Glue. I have used this on other projects and it works very well. The fact that it expands 3 to 4 times will work to advantage in that it will force all the air pockets out of the overlap and make a perfect seal, I think. Once the glue is set, than I can put a bead of silicone around the edge to finish. The Gorilla Glue company has confirmed that the glue will bond these materials.
My concern is that by boat repair book recommends not using polyurethane for this purpose - not reason was given. The only issue, and it is not minor, is that you only get one shot at it. If it does not work or goes wrong, you have a real big time mess on your hands.
Any thoughts out there?
Murray
Murray
