polyurethane gloss or varnish on cabinet doors?
john
Thinking of refinishing the cabinet doors below. I like the gloss or semi-glos look. Any problem with using a good polyurethane?
Don Bodemann
No problem with the poly but
I suggest you go with the semi gloss. If you use gloss it will be a liitle "much" IMHO
john
don, thanks for your suggestion...
I think that they were originally oiled without any sealer. Do I need to strip them first and if so with what. I was planning on a very light sand and then tack cloth wipe.
C
Carl foster
Oil finish removal
I found the easiest way was to spray on Castrol Superclean, let sit 10-15 seconds and wipe with damp sponge. In places two or more applications may be needed.
john
where do you find castrol superclean?
In auto, dept. or boating stores?
C
Carl foster
Castrol Superclean
K-Mart,Walmart,Auto supply stores. About $6/$7 a gallon
Barry
gloss
I used Minwax poly, water based, three coats, and it looks great on the interior. There was practically no smell, and I could recoat quickly even though I waited a week between coats. Weekend projects good luck with you project Barry
