polycarbonate tailing & fabricator needed
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
I am replacing the mid-cabin hatch on my H28.5.
The new Bomar Hi profile hatch which is slightly larger has a support rod & dog centered under the hatch. This presents a problem because I had planned to migrate the Nicro 1000 solar exhaust vent to the new hatch. The shaft of the vent wants to occupy the same underside space as the support rod.
So I though I'd just make a "spacer" about 3/4 inch thick and 7" round disc of smoked poly and drill out the the center to accept the shaft of the solar vent, and sandwich the disc between the solar's dome and the hatch surface.
I've called a couple fabricator but none do this kind of small job anymore and they don't even have a leftover tailing piece I can buy from those "big jobs". There's gotta be a better way than to buy a very expensive large sheet and you still gotta find some one to cut a 7inch diameter disc out of it. I could use my old Milwaukee keyhole bit saw from the original hatch install to cut the center shaft hole. 3/4" will take a while to cut but I could handle that.
Does anyone know who/where I can get this polycarbonate "donut" made/cut without spending a fortune? Preferably in NJ/NYC metro area.
Thanks for any guidance.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Jim: Why not just install the Nicro vent on the forward hatch? The interiors of our boats being so relatively small, it seems like it would do its job there just as well and not complicate the install of the new hatch.
jtm
Jun 14, 2004
314
Thanks Warren- I had contacted emco to cut my companionway polycarb boards - but given the "job size" at the time (2.5 yrs ago) it was, as they say... cost prohibitive.
I'll try the second party - stay tuned.
jtm
Jun 14, 2004
314
PS- Thanks kd will call them this week.
ps- I already have a forward Nicro day/night solar vent mounted just forward of the mast.
