PoliGlow Usage
C
Chuck
PoliGlow Question. Have you used PoliGlow on your Fiberglass boat? Where you satisfied with the results? Did you or would you use it again? Do you wax later? I purchased a 1993 MacGregor 26C in August 2007, and was thinking of using PoliGlow this spring. The previous owner had used it 3 or 4 years ago. Thanks for your input. Chuck
John R
a friend's experience
A friend of mine used poliglow on her houseboat when she had it hauled out. She was extremely happy with the result.
Daryl
Poliglow!
I used the stuff and was impressed. Of all the acrylic finishes this is the best and has less tendency to yellow over time. I wouldn't use it on a never vessel but I would use it on a vessel I was trying to sell. Removing the stuff ain't easy but I found a yearly recoat helps the stuff last
F
Franmara
Poliglow
I have used Poliglow for 8 years on my Hunter 37 and highly recommend the product.I freshen up in the spring with a few quick coats and on occasion I have recoated an area the has been scraped or stained. I find Poligow as easy as any wax system that I have used over the years.
jimq26
Jun 5, 2004
860
Great product - works exactly as advertised.
PoliGlow makes the topsides on my 1973 G-26 look like new. We also use it on the deck and cockpit areas that don't have a nonskid surface, and are very pleased with the results. Make sure you follow the instructions - very simple and easy to apply. Removal is very easy as well (see the link). You must do yearly maintenance to ensure a proper finish. DO NOT USE WAX WITH THIS PRODUCT!!!!
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Works great
I've been impressed with PoliGlow. It looks great, lasts a long time, and helps keep the boat clean. A bottle will last for probably three seasons for your Mac. Two things - make sure you get the area you are going to cover absolutely as clean as possible, because you will be sealing in any stains, dirt, etc, and make sure you don't drip poliglow anywhere you don't want it to go on. Removing it is difficult. Manny
G
George
Poliglow
Suggest you search the archives on this subject as there is a wide range of opinions on the matter. Proper preparation is essential. Unless you are committed to applying and maintaining the product PRECISELY as recommended you are probably better off using a good paste wax.
Dec 3, 2003
544
None None Rochester, NY
Wonderful stuff
I have used it for years, and will continue. The only caution I have is not to use it where it might be scuffed by your shoes, as in the cockpit. The scuff will show much quicker than wax and will be more difficult to clean. That said, prep, apply, stand back and smile.
Dec 13, 2006
68
Beneteau 323 Milwaukee
poliglow is fine
I used poliglow on my previous boat, a 1987 hunter. It worked very well and looked great on the older boat. It is true the boat must be clean with no dirt or stains before you apply it. If it isn't then you are sealing in the dirt or stain. It gave the boat,which was older and dull,a very nice shine and wet look. I don't think it looks as good as a traditional wax and I would not use it on a newer boat. I wouldn't hesitate to use it again on an older boat with a dull finish and I do feel it was easy to apply and lasted a long time.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Mop and Glow
Isn't that like mop and glow for your kitchen floors? How would you strip that off if needed?
jimq26
Jun 5, 2004
860
Re Mop & Glow - you didn't read the link.
If you did, you would understand what the product is, about the UV inhibitors, and how to remove (strip) it if you wish.
Feb 6, 2007
59
Hunter 450 CC Liberty Landing, Jersey City NJ
Just a couple of suggestions
Don't apply in very warm temps or real direct sunlight if you are also doing the top deck. It can dry too quickly leaving bubbles. If it does you can lightly sand the area and re-apply. I agree with everyone else, have a very clean boat, then nice smooth even strokes along the topsides of the hull. Keep rinsing out the applicator too, keeping that clean with less build up makes for successful results. You'll love this product, we certainly did!
Tim R.
May 27, 2004
3,626
Works well
You need to follow the directions for good results. They are quite simple though. I have also noticed that Poliglow works better on light colored gelcoat. Here is my previous boat. A 1977 Pearson 28 with a new bottom and 5 coats of Poliglow on the topsides. Tim R.
Richard
In a word, CRAP!
Our experience was a sort of yellow, ridged finish. And what a PITA to get the rest of it off that didn't flake off. But other than that I'm sure it is a wonderful product.
Jun 3, 2004
730
Catalina 250 Wing Keel Eugene, OR
We loved it
Used PG on our C22. The stuff works wonders if you follow the directions. I did a small amount of work and had one of the best looking hulls at the marina. As an alternative you could spend lots of time and $ grinding and polishing away at the gelcoat. I prefered to sail.
Jul 24, 2006
27
Oday 25 Anchorage, Alaska
Just don't forget to reapply
I think the stuff is awesome....with one execption...do not forget to re-apply BEFORE it starts to flake, if you do, you are in for a long miserable process of removing it.
