Brett
My new boat (Hunter 31) is coated with PoliGlow. I tried to wash the hull and was not able to get all the run-off trails and waterline scum off. On previous boats I have used Zing to clean the waterline and Meguires cleaner/wax or cleaner followed by wax to clean off the stains that normal washing will not remove.I went ahead and used Zing on the waterline (probably needs to be raised) and it worked quite well. It did not seem to remove the PoliGlow, although I thought it would. I decided to follow that up with the cleaner wax because I do not want to recoat with PoliGlow until I figure out how to remove all other stains from the hull.The cleaner/wax worked very well, made the surface much smoother than the cleaned PoliGlow by itself, and removed additional run-off stains and the like.Question? Would it be bad to cleaner/wax the entire hull. I would be waxing over a PoliGlow surface. Concerns are:Would buffing cut through the PoliGlow. It does not seem so?How long will the PoliGlow last under a yearly waxing and buffing?What will happen should I need to recoat with PoliGlow?I kind of like buffing and waxing my hull (kind of relaxing, like mowing the lawn) and so I am not convinced that I would like to stick with PoliGlow. My current thoughts are to just cleaner/wax it and over time the buffing of the cleaner will gradually wear down the PoliGlow until I am at gelcoat. I have found that by buffing a cleaner/wax my boats get a better shine every year and eventually require very little effort to clean/wax in following years.If this tack does not work I would likely remove the PoliGlow when I get my boat to it's home boat yard in a following year. (This year I am maintaining two boats, 1983 Cal25 for sale).
