Pole needs work
361
Hunter 30 Middle River MD
The pole used on the jib seems frozen. This might not be a major issue if it was set right but with the furler and new sail its wrong.
Suggestions on how to brek it loose enough to adjust?
Rick D
Jun 14, 2008
7,208
I used PB Blaster and soaked it overnight. Be careful, it stains. Then, I clamped the end and turned the sleeve back and forth until it broke loose. Then I took it apart, washed it well, lubricated the tubes and reassembled. (I assume this is a telescoping pole.)
PS: Fastbottoms: that was funny!
Aug 23, 2009
361
Ah this make me a Pole Volter as I drive a Chevy Volt, but kdding a side thanks sounds like a workable approach.
