Did you even read what I wrote??? I said that the AC NEUTRAL AND GROUND lines were tied together on the boat. This is a really bad idea and against ABYC specifications IIRC. The AC and DC grounds should be tied together, even if you aren't using a Galvanic Isolator.
If you have no submersed metal, then a galvanic isolator does little for you.
I thought that the common practice IS to connect the ac and dc grounds, PROVIDED you are using a galvanic isolator OR an isolation transformer. Every boat connected to shore power should have some isolation device in my humble opinion.
