the northwest is a big area, but for the puget sound/san juan area and south, we have mild winters, relatively speaking...
most years all you need to do to winterize here is to open the engine compartment to the interior of the boat so you can get some heat transfer to the engine. it doesnt take much but just enough to keep it above 32-33 degrees...
we dont usually get too long of freezing spells, and when freezing temps do arrive, we usually have sunny days that help warm the insides of the boat to bring the temps back up... and seldom does the temps stay cold long enough to cool the water down to the freezing point.
problems arise when either there is snow on the deck and then the temps dip for a couple days, or when the temps dip and then the fog sets in to blanket the cold in.... when no sun is able to get to the deck and warm it in the daytime, the engine compartment will stay below the freezing point for many hours, then bad things will happen...
last year was a bit colder for a bit longer, but still, if you keep the engine compartment above freezing and you will be fine.... but you have to make sure the breakers dont trip and shut the power to your heater off...
there are others who will flush antifreeze thru the system, but in the many years ive been boating here I have never seen the need, unless you cant keep the engine from freezing by other means....
