Plywood repair from leaking portlight
Dec 22, 2012
102
Islander 30 Bahama Keyport
Please direct me to the correct forum if this question doesn't fit here. I have two leaky portlights that I am replacing this weekend. In both cases, there is water damage to the plywood on the interior walls, making it soft beneath the surface. Is there a technique to somehow fill the soft area with an epoxy or other material without having to cut out the wood? I could never match the remaining wall with that approach and since the wood is not structural, just reinforcing it would suffice for me. Advice?
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
Can you post a photo of the damage? Thanks.
May 20, 2016
3,015
You could try a penitrating epoxy if the damaged area is non-structural.
Les
Gunni
Mar 16, 2010
5,937
Acetone will weaken epoxy, but in this case who cares. West or MAS thinned with acetone to the desired viscosity will do the job.
