Take it off!
In order to rebed the teak strip, I took the plexiglass apart from the poptop. It is pretty easy with two people. Here is how:1. Slide the plexi hatch back and raise the pop top.2. Prop the pop top open with something sturdy (I used a boat hook). OR tie it off to the boom, above, using the pad lock ring as a tie off point.3. While a helper holds the plexi from falling down, unscrew and removed the wood side piece on ONE SIDE ONLY.4. The plexi can now be removed -- it is heavy.Reverse the process to put it back after fixing.I used 3M 5200 to glue the strip back on in addition to the screws. Also put a bead of caulk on the forward edge and extended the bead to the edge of the plexi. The wood stops a little short.Good luck and fair winds,Tom
