plexiglass hatch sealant
jerry mitchell
I am replacing the plexiglass in my hatch...my question is what type of adhesive/sealant should I use on the bottom of the plexiglass between that and the hatch aluminium frame...should i clamp the plexiglass in place while the adhesive cures? I also plan on sealing the top of the plexiglass with silicone. Any suggestions from anyone having done this is appreciated.
Dec 2, 1999
15,184
Check with the Mfg.
Jerry: Contact the mfg. They will give you the proper product for this purpose. You will want to mask the frame and the plexiglass when you apply the sealant. Let it cure and then remove the masking tape.
