Hi All,
Yesterday on the way to race on OPB's I realized I had forgotten my gloves so I made a trip out to my boat to get them and to also photograph the "Inverter Inefficiency Post".
While standing on the dock I began to admire a beautiful older 40+ foot CCA designed boat. As usual my eyes automatically scanned the chain plates, clevis pins and turnbuckles as has become second nature.
All of a sudden I see this:
A used cotter pin bent up like a Chinese circus freak that was un-tapped and sharp a chain plate cap peeling up from the deck. I was concerned about the chain plate caps pulling up and thinking the chain plates could actually be loose?
I then began to look a little closer and saw this:
So I knocked on the hull and the owner came on deck.
"I don't want to alarm you sir but you are missing cotter pins in your turn buckles and the intermediate shrouds clevis pin has no pin in it. Also your cap shrouds cotter pin is about to fall out."
"Oh I never put pins in."
"And you're not concerned about that?"
"Should I be?"
"Well having been on a boat that lost a spar I sure would be that's why I'm mentioning it to you."
"They've been like that for a while though."
"You've been sailing without cotter pins on purpose?"
"It seems to be fine."
At this point he walks over an grabs the cap shroud which was like limp spaghetti.
"Hmmm that's pretty loose."
"Yes and my concern is that you only have about 1/4 of an inch of threads left on your turnbuckles."
"I'll have to tighten those."
I then pointed rather loudly at the clevis pin, if you can visualize that, and he actually got surprised.
"Wow I didn't know that had fallen out."
My point here guys is to bring attention to your rig. Try not to use worn out and bent cotter pins and please remember that turnbuckles will back them selves off. Those holes in the threads are not just for ventilation...
P.S. I almost said nothing because I honestly thought he was being hauled out for the season. If you notice something like this never assume. This guy was NOT getting hauled out! He is a very nice guy who I think now understands why he should have installed cotter pins and actually bent them over.. He thanked me for pointing this out and intended to fix it right away. I'm glad I actually said something...
Please visually inspect your rig every so often...
"Should I be?"
