Please help
Rick DeGregorio
I removed my exhaust riser in the fall to get cleaned out, I was getting alot of soot on my transom. I purchsed a new gasget and installed riser, simple, 3 bolts, went together easy, put in antifreze and leaked out. I took it apart and used a little permatex still leaks. I did it again and let permatex set overnight then tighten still leaks. I've tried 5 times.I've called my diesel mechanicut he's so busy I don't know when he'll show up. Any idears, I want to get in the water in a week or so. thanks for any help
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Exhause Riser
You didn't state what kind of engine you have. Or where exactly the leak was. I would first suggest that you try to determine exactly where the leak is. Around a bolt, top of the riser, bottom, etc. Then inspect that particular area. Also you didn't state how it was cleaned, but if it was vatted in a caustic solution and had a thin spot, the cleaning solution may have simply eaten through it. Can you give more specifics.
Bill O'D
Mixing bowl
This sounds like the U-shaped unit that mixes exhaust with water. On Yanmars they typically last 3-5 years before coking up and choking the engine dead. Ship's store probably carries them for $150 apiece. I agree the leak could be coming from a pinhole. More important is the coking up of the interior, which see.
