to dlewis812
relax a bit, my friend and realize that you'll laugh at this later on. The other day I took my boat out and the motor quit after about 10 minutes.... I sailed on out, determined to enjoy a perfect memorial day, but I kept thinking, @#$%% I have to take the thing in and have it checked out and I don't feel like messing with it----pooor me.... then about an hour later I thought...Hmmm, did I open the vent on the gas tank?...and that was it! (kind of embarassing since I've owned the boat for seven years)Here's what I suggest: Start at the faucet and track the water hose backward to find the pump. Determine if the pump is manual, a simple electric type or fully pressurized with a pressure tank. Since it's a Cat25, if there is no manual pump then the owner probably added an unpressurized system with a simple electric pump between the tank and the outlet. Then look for a switch and a fuse, on the breaker panel or in line. On my system the water pump is on the breaker panel and it makes a big racket when you open the faucet... I hate the thing, one of my projects is to convert back to manual. Besides it wastes water.So be patient and inspect your system... then... get back to us with a quick description of it and I'll bet you'll get some specific answers.
