Steve, how many different makes of rotomolded
have you measured? You "personally know people who've measured rotomolded tanks"...how many tanks from which mfrs have they measured? Have they only compared wall-thicknesses or matched the thinnest wall against the minimum specified wall thickness? If the thinnest wall meet that spec, is it a flaw if another wall is thicker? Mass produced cheap thin-walled tanks (the usual OEM quality) do indeed have inconsistant wall thicknesses--some walls thinnner than specified. Otoh, the best quality rotomolded tanks may vary SLIGHTLY, but if the mfr's specs call for a minimum wall thickness based on the size/shape of the tank, every wall is AT LEAST that thick. And all corners are reinforced...approximately 50% thicker than the walls of that tank. Welded tanks, otoh, are only as strong as the quality of the weld. As you said, they're labor intensive...subject to the attention span, skill--even whim--of the welder. They CAN be as strong as a seamless tank, but you take your chances. NO good quality rotomolded tank has ever split at a seam...the same cannot be said of welded tanks. I would not pay the premium for one unless there was NO other choice. As for limited selection, Ronco has 400+ to choose from...how many would you consider enough? Your condemnation of rotomolded tanksis simply not warranted.
