Plastic Props
A
Andy
I've seen ads for so-called computerized props made of "composite" plastics designed especially for Yanmar 2GMF20 engines. They are touted as being "more efficient" under sail as well as under power. I have a 1988 Hunter 30 with this engine, and I am not having a particular problem, but I am always interested in improving performance. So, I wonder, to what extent would my boat's performance be improved by a prop which is not necessarily designed for my boat, but for my engine? What are the pros and cons of the "composite" material props? Thank you.
Dec 2, 1999
15,184
Been using one for 2 years.
Andy: I have been using one for about 2 years now. I was sort of difficult to compare because the stock prop on our H'31 was over-propped. It was 15 x 12 and should have been more like 15 x 9/10. The new prop was closer but still not exact. It has worked OKAY but I would not say that it was any thing special. If you are looking for a new prop because you need to replace the old one, I'd say give it a try.
K
Kevin l. Woody
Comp Prop
Dear Andy, Thank you for your note. I have seen the CDI prop at shows and I have spoken to Joe, the props founder, and I my self would find it difficult to ever make some of the claims which I believe the company makes about the prop. I have no problems in using composite in propellers and believe that future propellers will start popping up as the method of manufacturing begins to come down in cost. I do not, however, believe the claims of less drag and greater speeds. If increases were present I would believe that they would be small. I hope this helps. Kevin.
Dec 2, 1999
15,184
Andy
Andy: I think Kevin is correct in his assessment of the composite props. Pretty much what decided too.
