My boat (1983 vintage) is missing some water pipe fittings. The previous owner never got around to fixing the supply pump that pressurizes the water system which supplies water to the sinks and shower. The parts that are missing are used to connect semi flexible 3/8" inside diameter gray plastic pipe to tees and elbows. To make a connection to another fitting you slide a threaded coupler over the pipe then slide a metal washer like part over the pipe than a gray plastic ball with a hole in it slides over the pipe. The ball part mates with the adjoining fitting which a guess makes the seal. Does anyone know what this plastic parts are called and where they can be purchased? Thanks.
