Plastic housing whitener suggestions
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
If you got this far, I'm starting my shifter and throttle cable replacement. I have the wet compass and the base holding the compass on top of the Edson pedestal off. The plastic base has really yellowed over the life of the boat, even with the helm cover. Does anyone have any suggestions on how to renew/whiten it as I wait for my new cables to arrive? Thanks!
colemj
Jul 13, 2004
1,175
There is no renewing it, only covering it (paint, vinyl, etc). You could wet sand the yellow layer off, but it will just yellow again even faster. I hate white plastic things on boats because they always turn an awful yellow color.
Mark
  • Helpful
Likes: Justin_NSA
Jun 2, 2004
3,674
There is some sort of hairdresser stuff that whitens plastic. Developer is what sticks in my head but I'm not sure that's it. I used it on something I was working on and was surprised at the results. I think I still have the bottle on the workbench somewhere, unless it got tidied up without my concurrence.
Oct 6, 2007
1,180
Hunter H30 1982 Chicago IL
I lightly sanded mine and spray painted it with Rust Oleum, semi-gloss. The color was called Refrigerator White. That was in about 2008 and it still looks good because it’s covered.
  • Helpful
Likes: Justin_NSA
Jun 2, 2004
3,674
It is developer. Basically, it is hydrogen peroxide in a gel. You can pick it up in beauty supply stores. Lots of instructions for the application on YouTube. Smear it on the plastic, put it in a zip lock bag, then set it in the sun. Amazing how well it works.
Jul 7, 2004
8,542
interesting. I may give it a go. Any side effects? Will it get rid of my grey hair?
I'm guessing it is safe for plastic (?)
Jul 7, 2004
8,542
I just picked up some developer #40 at a beauty supply place. I told her what I'm using it for. She says lots of guys come in for it. Hunters use it to whiten bones, techy guys use it on older computers to restore the original color. I've been enlightened! :thumbup:
Sep 24, 2018
4,805
Catalina 30 MKIII Chicago
I can't wait to see the results! Please take before and after pics!
Likes: Dalliance
Jun 2, 2004
3,674
Not that I know of
Yes, right down to the scalp
Seems to be
Jun 2, 2004
3,674
We want to see the before and after shots.
It's killing me that I cannot remember what I used it on
Nov 20, 2025
28
Alden 60' Schooner Killybegs
This really depends on the kind of plastic. Not too much you can say about what works and doesn't work until you know that. I'm pretty sure hydrogen peroxide only works for ABS. There aren't a lot of other things you can do that actually work well enough to be worth the effort. You can prevent the yellowing with some coatings but they require too much maintenance for my disposition. If it isn't ABS, the only decent options I know of are to sand and polish up to 3000 grit wet sand, which is labor intensive and probably kills fish or something. Or sand lightly and paint as others have suggested.
One more idea that works for some parts but probably not the part you are dealing with. We had a plastic compass ring and cover that were looking a little worse for wear. Took them to a foundry and they just cast them directly in bronze, using the lost-plastic method. Now we have bronze parts that are perfect replacements for the old plastic ones.
Jul 7, 2004
8,542
The developer has been on a couple days now. It might be a little whiter, but not nearly as white as the unexposed places. I am trying a reapplication before I give up.
JRacer
Aug 9, 2011
1,409
SEM Color Coat paint preceded by Bulldog Adhesion Promoter. Pick it up at an automotive paint store.
Apr 22, 2026
1
Sabot sailing dinghy 8 Homeplace Pond
Great idea! Not inexpensive, but still starts me wondering what could use bronzing around here...or what perverse prank could be pulled with this (bronze toothbrushes in the cups next April 1).
  • Ha
Likes: LLoyd B
Nov 20, 2025
28
Have you been exposing it to UV? The hydrogen peroxide is only half the technique. It has to be exposed to UV to do its magic, so far as I know.
Jul 7, 2004
8,542
I have not been doing that. I will reapply and leave it in the sun
