I had to remove the sending unit from Beneteau 36cc which has a plastic fuel tank. The reason for removal is irrelevant at this point, but after replacing the gasket and reinstalling the unit it has leaked ever time I filled up the tank. Is there a special gasket? Or perhaps a sealant that can be used to seal this tank back up? Being a plastic tank, I can not torque the screws very hard as it would simply strip out the holes. Here is a photo of sending unit with wire connectors removed and the top plate next to the unit.
