Plastic Fuel Tank Leak from Sending Unit
Apr 26, 2014
34
Beneteau Oceanis 36cc Everett
I had to remove the sending unit from Beneteau 36cc which has a plastic fuel tank. The reason for removal is irrelevant at this point, but after replacing the gasket and reinstalling the unit it has leaked ever time I filled up the tank. Is there a special gasket? Or perhaps a sealant that can be used to seal this tank back up? Being a plastic tank, I can not torque the screws very hard as it would simply strip out the holes. Here is a photo of sending unit with wire connectors removed and the top plate next to the unit.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
I am following this as I worry about same thing. I had to remove the sending unit a few times and always worry about the seal as like you said can’t really over tighten the screws. So far so good...... however I worry when filling. I would almost think on these tanks there would be something like butyl tape.... obviously would have to be made to withstand fuel.....
Greg
Gunni
Mar 16, 2010
5,937
That is a one-use compression gasket, you need to replace it, not reuse it. Don’t goop it up with anything either.
NYSail
Jan 6, 2006
3,178
Wonder where one would get replacement gaskets....... get the sender model and call manufacturer or I assume one could be made using a basic fuel friendly gasket material from an auto store....
Greg
Apr 26, 2014
34
Yes, I did replace with a new gasket from NAPA auto parts, not a OEM part. Perhaps the original was more of a soft, thicker material?
Apr 26, 2014
34
After reinstalling I applied Permatex Ultra Black around the outside of base. It did seal the around the outside of base, and think that did not leak. I believe the fuel was actually coming up around the screws. So, I am going to get a new dry gasket and apply a small amount to gasket and screw threads prior to screwing down.
Greg
Dealer has not been very helpful. Will try again today with phone call. He has referred me to a boat yard in the area who also is not been helpful.
