plastic crib boards
Apr 26, 2010
434
catalina 22 lake tillery NC
Has anyone used the plastic on their cat 22? all of my teak is beyond help and I have been thinking of going plastic starting with the crib boards. I was wondering about the pros and cons do you know of any?? Thank you Alan
dzl
Jun 23, 2016
159
Catalina 22 Trailer
I have them. They came with the boat. They'll definitely last forever, but they're hard to clean. They have a textured surface so when they get dirty it's a pressure washer job to get them clean. If i were to replace them I'd go with smoked acrylic.
T_Cat
Aug 8, 2014
333
Catalina 22 1987 New Design. 14133 "LadyHawke" Modesto CA
I replaced all the teak. (A lot was missing or cracked anyway) I like it. Most parts were easy to install. The weather board for the sliding hatch was a PITA. Much cheaper than teak. No maintenance. I miss the teak though.
This is before trimming the top hatch board and weatherboard....
Russ
850
Catalina 22 Minnesota
Everytime I need to varnish I think of going away from wood. The season is so short in the north. But I found this site which may be a happy medium anyone ever used them?
https://www.plasteak.com/
Jul 25, 2016
200
Catalina 22 Sacramento
I recently purchased some used, but they don't fit. They were from a 1974 C22 and I have a 1972. I thought they would be the same but I was wrong. I am hoping to be able to cut them to size. We will see soon enough. If not, I only paid $25 so I am not out a lot of money.
Sep 8, 2014
2,551
I have them too... You need a compound miter saw to make the cuts. Kind of PITA to get the angles right. Best thing is to use the old teak as a guide. I think smoked acrylic would be more complicated and equally expensive. Unless you use just one piece you'd have to use a router to cut the bead and cove between 'planks' that keeps everything water tight (ish).
Sep 30, 2013
3,646
You don't think they could just be cut at an angle where they join? That's what I planning to do on the Vega. Am I overlooking something?
Sep 30, 2013
3,646
I think this looks dead sexy. :)
I forget whose boat this is, someone here at SBO if I recall.
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
2 pieces. Cut the width slightly small, so they slide easily.
Taper jig on table saw works well, too. Jig saw for the upper arc.
1/4" interlocking rabbets form a watertight seal.
Bottom piece, rabbet the outward face, top piece, rabbet the inside face.
Easy-peasy. Go to YouTube to see how to burnish the edges.
Wish I had pictures. I'll try to remember to take a couple tomorrow.
