Placement of Icebox Compressor
Feb 27, 2004
172
Hunter 335 North East, MD
I am considering getting a conversion kit to turn my icebox into a refrigerator and would be very interested to hear where others have placed the compressor and how much airflow the compressor needs. I have a deep locker in the galley in which we use to store a couple of pots and pans that's only about a 3 foot run from the ice box which I was considering- any info/feedback would be appreciated
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
if that is a dry place it will be good as long as it has good air flow...isotherm makes some water cooled unites that you may want to look into they work great a little pricey but well worth the investment
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
look at owner mods under the boat info tab
for the 34 the mod has the compressor and condensing coil from a dorm fridge
mounted in a space against the hull outboard of the icebox
Oct 14, 2005
2,191
N. Veater...
I've seen some mounted in aft lockers in other boats. H34's have used the space outside of the ice box as Splax pointed out. The 33.5's layout is different.
If need be, a bilge blower could be rigged to come on with the compressor to aid heat dissapation in a tight space.
Hunter 35.5 Montréal PQ
Hello,
We have a 1991 35.5 and have had a Adler Barbour system installed in our boat in 1992. The unit is on from May to October every year since 1992 and still work very well. The unit has a vertical freezer (large vertical evaporator). The compressor is on the port side, close to the bulkhead. The CNG reservoir is just aft of it. We installed 2 louvered panels about 8" X 8" in the vertical section supporting the settee. It sure give adequate ventilation. I am including a picture with layout.
JimR
Sep 25, 2008
6
Hunter 33.5 San Pedro, CA
Compressor placement
On our 1991 33.5 the compressor and condenser are mounted behind the stove. I can provide pictures but not for a couple of days. Works fine. The original alcohol was replaced with a propane stove top and a microwave below.
121
Hunter 430 Shelter bay, Panama
mine is in the aft under the lazerettes and behind the main berth. there are panels with louvers in them to allow airflow from the inside of the vessel.
