pivot pin
23
Captiva 240 Port Richey
Just replaced piviot pin on a 24 footer. Replacement pin is Stainless Steel. Just been told it could be subject to corrosion...anyone out there experience thiis?
Ross
Jun 15, 2004
14,693
This is on the center board? Stainless steel below the waterline is deprived of oxygen, so,yes corrosion could be a problem if you sail in sea water. Bronze would be a better choice.
Feb 25, 2010
23
Computer just crashed so if this is a re-run Ross..many thanks..last time I saw Perryville, MD was in boot camp but believe it was Bob M itchims home town.
Ross
Jun 15, 2004
14,693
You must have been at Baimbridge. Been closed for 35 years now.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Used a stainless steel pin on my 23' O'day. Steel centerboard, iron keel. No sign of corrosion after 12 years in salt water.
Feb 25, 2010
23
Hey many thanks....I have a hunch the answer could lie in the quality of the SS. There is alot of poor quality SS on the market...much of it from Asia. By the way SS got its name Stain-less because when it first came out it stained less then other steel.
Oct 18, 2010
58
Anon Anon Anon
I woud have used Zinc.. Just cheap plain old zinc.
Sure zinc will surface rust but so long as it is not touching any other metal it will last longer and hold up better than SS. A plain old zinc bolt is almost 10 times stronger than any plain old SS bolt.
Ross
Jun 15, 2004
14,693
Perhaps you mean galvanized. Zinc is the sacrificial anode that we attach to our propeller shaft. I have never seen a bolt made of zinc.
Oct 18, 2010
58
Anon Anon Anon
Those anodes are not hardened... Any old bolt sold at Home Depot is hardened zinc bolt.. The zinc anodes and zinc bolts at Home Depot are 2 completely different animals
Oct 18, 2010
58
Anon Anon Anon
Go to Home Depot and they will offer 2 choices of nuts and bolts. Galvanized and Zinc for general purpose. The small sticker below the product for sale will even say ZINC right on it.... They are actually steel with a zinc coating to resist weather.. Straight steel is stronger than SS. So long as the bolt or boat is rinsed down with water and the bolt is not touching any other metal it will perform just as well as SS.. Sure it will surface rust..
Jul 11, 2010
7
Pearson peap7010m84d Marion, MA
How to change pivet bolt?
Would someone explain how to replace the pin.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
There are a variety of arrangements used by the boat manufacturers.
Might want to start a new post for this question. It's a great topic and will get more attention that way.
