Piping air conditioning drains overboard
263
Hunter 36 Cobb Island
I remember someone talking about routing the AC condensate drains into the AC cooling water flow and overboard. Is this "eductor" something you buy somewhere? I was looking in the WM catalog and didn't see anything.
Ross
Jun 15, 2004
14,693
I think it may be called a "tee" fitting. You perhaps cut the cooling water drain in a convenient place fit in a "tee" and connect the condensate drain.
Nov 24, 2007
36
hunter 34 venice
Jorge,
you are looking for a Mermaid condensator which will take the condensate from the catch basin and send it out through cooling water effluent. I have this device and it works beautifully keeping all the condensate out of your nooks and crannies. You can find it in the defender catalogue.
Good luck,
Dave
Nov 6, 2006
10,218
Be careful with the installation.. a small piece of debris will sometimes (very slight chance) make an eductor like this stop pumping or worse, cause the flow to go out the suction side.. Google "eductor pump" for info on how it works .. I wouldn't leave one on a boat that is untended with the AC on, but if you are aboard most of the time when the AC is running, it is a fine way to avoid a wet bilge
