Mort, The speed over ground is what is really important anyway. Its speed made good that's more important. The wheel is affected not just by the boat movement but by current running over it, hence it is NEVER really accurate. Also the crud that y'all are fighting to clean affects its performance & accuracy. Just a lil crud buildup will induce drag & affect the speed at which the wheel does, or doesn't turn. The knotmeter also does not take into account lateral forces slowing the boat, tidal current, etc. that effect speed. GPS is far more accurate. I have the answer to solve the problem of the rotating knotmeter: Get rid of it! It's a piece of history - about as accurate as Loran. That's why they don't even sell them anymore. GPS is the wave of the future. Check it out sometime. You can pick up a Garmin handhled for a hundred bucks. Why anyone wants to fool with the knotmeter wheel anymore is beyond me. An apparent wind indicator is a much more valuable sailing instrument then any aboard. As far as doing things old school, I could also use a lead line, but that would just be silly.
