FYI, that toggle at the top is also required for the Schaefer snap furl (what I just ordered).
Another picture of a Johnson lever on a 26S at about its minimum distance which I could live with (7 3/8 inch). The clean access to the anchor is one of the reasons Im going to a furler. When I drop my hank on, its a yard sale all over that area making the anchor a hassle to get to.
Sumner, I spent some enjoyable time a few days ago tagging along on your adventure (great job) and one of your pictures illustrates the visibility issue that comes along with a larger Genoa
This picture below is from your web site with the larger Johnson lever extension (I figure you have about 11.5 inches of extension including the extra toggle at the bottom). I think you have a 135 Genoa
Since we have the same exact boat, its interesting to compare the visibility you get with the 100% jib that is as low to the deck as is possible (my picture below). With the larger Genoa, even with it raised, as the boat heels the sail again begins to block the view. The smaller jibs are cut so that you can heel a lot more and see where you are going.
Just another trade off... I am going with a 110 so I dont think I need to raise the jib for visibility - but I wont know until I try it on the boat. I do think I want the higher tension but the reason is pointing ability that I hope is still good with the 110 on a furler. I have not seen it yet but I understand the Schaefer furler also allows you to adjust the tension on the head sail with a halyard (that I already have running back to the cockpit).
